How do you state the range for each row?
Hi Friends,
I'm having difficulting in setting a range of numbers for each row in a 2D array.  The description of the program is listed below:
A VI that outputs a 2D array with 10 rows and 5 columns. The first row should contain five random numbers in the range 0 to 1, second row numbers in the range 1-2..and so on to the tenth row, which should contain five random numbers in the range 9-10.
I've attached my program what I've worked out.
Message 1 of 19
(3,485 Views)
One fairly straightforward approach
Message 2 of 19
(3,482 Views)
To create a range of random numbers, it is rand*(max-min)+min.  Make a subVI that does this calculation.  All you have to do then is put this new subVI into 2 FOR loop, autoindex out, and you have a 2D array.
Message 3 of 19
(3,481 Views)
yes, I've done this part.  I've included the VI in my post.
I want the first row in the 2D array to range random numbers from 0 to 1
the second row to range random numbers from 1 to 2
the third row to range random numbers from 2 to 3
the fourth row to range random numbers from 3 to 4
the fifth row to range random numbers from 4 to 5
the sixth row to range random numbers from 5 to 6
the seventh row to range random numbers from 6 to 7
the eighth row to range random numbers from 7 to 8
the ninth row to range random numbers from 8 to 9
and lastly, the tenth row to range random numbers from 9 to 10
Message 4 of 19
(3,470 Views)
I'm not getting you...shouldn't there be iniial value for max and min to do the sub-vi
Message 5 of 19
(3,468 Views)
Take another look at the snipett I posted earlierSmiley Wink
Message 6 of 19
(3,465 Views)
I tried your idea and this is what I have 🙂
Message 7 of 19
(3,461 Views)
Try that again
Withou the odd display formating
Message 8 of 19
(3,453 Views)
where do I get the array from on the block diagram like in the pic you posted.
Message 9 of 19
(3,448 Views)
After running the VI, he right-clicked on the output wire and selected "create constant".
Message 10 of 19
(3,430 Views)
