How do you tell two different cursors to move to different places?
Sorry if this has been asked before but I couldn't find the answer anywhere.
As I said, I'm trying to get two different cursors to move to two different places on the same graph. I have the values I want them to go to, I'm just not sure which function or command to use. I'm using LabVIEW 8.6. Thanks for any help!
(3,342 Views)
Accepted by topic author WCR
WCR,
You would have to use the property nodes of the graph to move the cursors programmatically. The properties of interest are Active Cursor and Cursor Position > X and Cursor Position > Y. Use the Active Cursor to specify (by cursor index) which cursor you want to work with, then set the X and Y property values, then set the next cursor as the Active Cursor and set its X and Y property values.
20255i0F52CAF2AE88B872
(3,333 Views)
Thank you Rob.
(3,321 Views)
