How does LVRT handle an Ethernet card?
I need to add a second Ethernet port to on my LVRT PXI system to control an instrument via TCP. How does LVRT handle the PXI Ethernet card? I'm sure I could put both the remote interface and instrument on the one Ethernet jack by using a hub, but I don't packet collisions in the hub to effect the determinism of the instrument.
(2,708 Views)
To my knowledge NI doesn't officially support multiple NICs at once in an RT box...but might in the future.
That said, I'd advise against a hub. Every time a packet of information is received by a hub, it is broadcast over all outgoing ports. This can lead to network congestion and packet collisions. Instead you should probably use a router, which is more sophisticated (routing tables, congestion control algorithms, etc.).
(2,708 Views)
