How does Rename Historical Data.vi work? I get error -1967386622
What format is required for the inputs to Rename Historical Data.vi?
No matter what I try, I can't get it to work, I get error -1967386622:
HIST_RenameNodesCORE.vi, Citadel:  (Hex 0x8ABC1002) The specified item, such as computer, path, or folder, cannot be found.
Given this hypothetical hierarchy in the Citadel 5 Universe in MAX, what should the inputs be to rename ZZZ to XXX ??
- My Computer (PC)
  - C__DB
    - AAA
      + AAA_Process_Name
         (traces)
    - ZZZ
      + ZZZ_Process_Name
         (traces)
Thanks!!
(2,824 Views)
Accepted by topic author FermWorks
This KnowledgeBase article describes this error exactly. The syntax is a little tricky though sometimes. To rename the ZZZ inputs to XXX we would need the following inputs to the Rename Historical Data VI:
database name: C_DB
existing name: \\ZZZ\
new name: \\XXX\
And for the ZZZ process:
database name: C_DB
existing name: \\ZZZ\ZZZ_Process_Name
new name: \\ZZZ\XXX_Process Name
To change both the folder and the process name we would have to run the VI twice through. Hope this helps some!
dK
(2,800 Views)
Thanks! That syntax is not obvious.
(2,777 Views)
