How does a VI notice, that there are new drivers (new files in a new folder) for some I/O modules?
I have programmed a VI, which controls several I/O modules from different producers (e.g. ADDI DATA and Meilhaus evt.).
If I update the driver of an I/O module, the driver will be stored in a new folder with a new file version name (e.g. C:\Meilhaus\ME-iDS\01.02.24.000\SDK\LabVIEW\access\meOpen.vi instead of  C:\Meilhaus\ME-iDS\01.02.21.000\SDK\... )
How can I make my VI to automatically realise, that there are new drivers for the I/O modules?
Now I cannot update any driver without changing the code of my VI or manualy changing the folder name of the driver, which is not good.
LabVIEW 7.1
Johannes
Message Edited by johanneshoer on 05-28-2009 11:11 AM
Greetings Johannes
Using LabVIEW 7.1 and 2009 recently
(3,058 Views)
If the installer for the driver creates a new folder and does not delete the old, then you can manually delete or rename the old folder. When you open the top level VI, it will prompt you to find the driver functions. Point to the new folder and save the changes. As long as the old VIs exist, LabVIEW will continue to load them.
(3,045 Views)
Another option is making a 'proxy vi' for every method.
If you have the OpenG builder installed you can open any of the API VIs.
This consist of a proxy VI
Proxy VI
Just after the path constant that defines which VI is called is a proxy Path VI.
Here is a screenshot of the code inside that VI:
 The only thing it does is creatte a path consisting of a folder with the called VI name.
Now if you move the driver to a new location the only thing you have adapt is the Proxy path VI.
But I am curious why would you place the code in a specific version folder, if you create an upgrade routine you could go without change the calling code.
Ton
My LabVIEW Ideas
(3,031 Views)
Ton,
Its not me, who does that. If I update a driver of an I/O Module, the new driver will be stored in a new location. I also wonder why they do that.
Fact is, the new drivers are in a new location.
Greetings Johannes
(3,015 Views)
