How does '?' in regular expression works?
I found regular expression as follows ione of teh VI.
Regular expression as: [-]?[.]?[0-9]+[.]?[0-9]*
The output is, it will extact the number from sentance.
Can any oneexplain me with an example (using multiple '?') please how does '?' works?
Many Thanks
Haneef
(3,010 Views)
From the help:
?          Marks part of a pattern as one that can appear zero or one time in the input. For example, be? matches be in believe, be in bee, be in beep, and b in bat..
So your RegEx consist of the following parts:
[-]?    0 or 1 times the '-' sign
[.]?    0 or 1 times the '.' sign
[0-9]+ 1 or more numbers (0-9)
[0-9]* 0 or more numbers (0-9)
Note that this regex doesn't deal with 'european' decimals using a ',' as decimal character.
Ton
My LabVIEW Ideas
(3,000 Views)
