How does number of "Samples to Read" come into play with "Continuos Samples"?
How come there is a the option to select "Samples to Read" if I set the "Aquisition Mode" to "Continous Samples"?  I understand that the rate that data is acquired is selected under "Rate (Hz)."  That means that every 1/1000th of a second I get a data point, so what's with the "Samples to Read?"  Is it ignored once I select "Continuous Samples"?  I can see that if you want a finite number of data points, then you would select how many under "Samples to Read," but what am I missing?  I can't seem to see much if any variation in my data when I make changes to number of samples when I use continous sampling.  Snip.PNG
(2,955 Views)
Read the help file for the DAQmx Timing VI.  It has to do with the buffer size.
aputman
(2,915 Views)
If using the DAQ Assistant, the Samples To Read is how many samples from the continuous task to read from the buffer each time the DAQ Assistant is called.
(2,906 Views)
