How does one use averaging with a for-loop?
I'm using Labview Express 7.0 and i was working on a VI and came across the concept of averaging data points for better accuracy. I would like to know how to do this. I have read a little bit about shift registers and kind of understand that, but I'm not too clear on how to average my data points in a for-loop.
Message 1 of 18
(4,755 Views)
If I understood correctly, you want to make an average within a for loop.
First of all you have a function to average an array (if you have it available in an array), but of course you can use shift registers to make that.
I made a small example to show you the two ways.
Hope this helps,
Paulo
Message 2 of 18
(4,749 Views)
More information is needed in order to answer your question. What is the source of your "data points"? Are you trying to average all of the data points, or are you trying to average the last x number of data points? If so, is x a constant or a variable? Once you have the data points that you are interested in averaging into an array performing the average is easy. Just use the "Mean" function under the Analyze-Mathematics-Probability And Statistics palette in the functions palette.
Message Edited by John Rich on 06-29-2005 11:17 AM
Message 3 of 18
(4,750 Views)
Try using the decimate array.vi on the output of the for loop. right click in the block diagram, go to Analyze, Signal Processing, Time Domain menu.
Message 4 of 18
(4,739 Views)
I'm aquiring my data from a mass spectrometer in increments of .5 amus. I'm reading the intensity. Instead of reading the mass spec. and graphing it right away, i would like to take 10 readings and average those. I would then take the average value and graph it on the xy graph. I don't understand how i'm going to read it ten times and take the average of the readings and plot them on the graph.
Message 5 of 18
(4,729 Views)
How are you communicating with the mass spectrometer? Are you wanting to take ten readings at each increment and then increment or take ten complete spectra and average these? I've not used a mass spectrometer but I suspect that you can do the former, which will most likely be the best option. Can you attach your code or at least an examples which shows the communication with the mass spectrometer?
Message 6 of 18
(4,724 Views)
I want to take 10 at each increment and take the average to plot on the xy graph.
Message 7 of 18
(4,720 Views)
How do you communicate with the mass spectrometer? Do you send a command to go to the next increment, wait for a response, and then send a command to take a data point? If so you should be able to send the command ten times to take the data point before incrementing again. You do this by putting the "Read value" function inside a for loop for 10 iterations. Enable indexing of the data output at the side of the for loop. You now have the array that you need for averaging.
Message 8 of 18
(4,718 Views)
Would the point-by-point averaging function alternatively be of use? Search for it and other pbp vi's in help
Message 9 of 18
(4,713 Views)
Here is the application, maybe someone can give me some better advice after looking at it.
Message 10 of 18
(4,710 Views)
