How does the default in scan from string work?
If the input to a scan from string is an empty string, and I have the default wired, shouldn't I get the default as an output (without an error)? see attached
Message 1 of 8
(4,324 Views)
Sorry, I enclosed the wrong vi.
Message 2 of 8
(4,314 Views)
I ran your VI and the output of the Scan From String is your default value when the input string is empty. What do you see when you probe the output? If you get an erro, what is the error number?
Message 3 of 8
(4,297 Views)
As shown by your vi, you effectivelly get the default value. However, an error is generated at the same times so you can decide about what to de next. You could wire an error indicator to the error output of the Scan from String terminal.
CC
Chilly Charly    (aka CC)
Message 4 of 8
(4,292 Views)
It's "Error 85 occured at Scan From String (arg1) in trial%20stat[3].vi" "Possible Reason(s): LabVIEW: Scan failed." If I hit Continue on the error dialog, it then gives me the proper default, but why should there be an error in the first place?
Doug
Message 5 of 8
(4,284 Views)
CC
But why is there an error in the first place? What's the default for?
Doug
Message 6 of 8
(4,284 Views)
It's a legitimate error because the scan did fail. The fact that you have a default value doesn't change that. The reason you get the error message is because you have the automatic error dialog turned on. If you were to rewrite your program to connect error in/error out connections, then the proper way to handle the error would be to set a trap for that specific error code and reset the error if found. To turn off the automatic error dialogs, Go to Tools>Options>Block Diagram and uncheck Enable automatic error handling dialogs.
Message 7 of 8
(4,279 Views)
Cool, thanks! I guess there are cases where you would want to trap that situation.
Doug
Message 8 of 8
(4,275 Views)
