How get ItemNames of Picture Ring
Hello everyone,
In fact I have tried to translate the texts of my front panel in several languages with a listbox by taking the property node itemNames and it work.
But now I'm asked to do it with a picture ring but I can't get the itemNames from the picture ring.
How can I get it back because I can't find it in property node please.
Thanks you very much for you help
(1,680 Views)
Accepted by topic author Ngouda
Use Property "RingText.Text"
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(1,675 Views)
How about the Strings[] property?
(1,649 Views)
Btw you might like the Hide Last Item When Running property (right click menu on the control). Usually a better UX then disabling the last item.
(1,647 Views)
Hi @PalanivelThiruvenkadam
Thanks you for you answer,
I test and I will back for you
(1,624 Views)
Hi @ ,
Thanks you for your answer.
I will test also proposal and will back for your.
(1,619 Views)
