How get started with NI 9870
I am using a cRIO-9014 with a few different modules. I am able to use the analog input module (NI-9205), but do not know where to start to use the serial interface module (NI-9870). What do I need to program on the FPGA to use this module?
(6,935 Views)
Are you programming the FPGA yourself or are you simply using the scan interface?
(6,930 Views)
programming the FPGA myself, which I can successfully do with the analog module, but I do not know where to start for the serial module.
(6,927 Views)
Imar,
Check out this forum with some good links and information on this topic.
Also, the LabVIEW Example Finder has a good NI 9870 exampl, which can be found under NI Example Finder >> Hardware Input and Output >> CompactRIO >> Module Specific >> Serial >> NI-987x Serial Loopback.lvpro. You can get to the Example finder by going to Help >> Find Examples from within LabVIEW.
Ben Sisney
FlexRIO V&V Engineer
(6,908 Views)
I am dealing with the CompactRIO 9074 and I have connected the 9870 up to this chassis. I am using the example virtual instrument that was recommended from James. I was able to input all of my Read_FIFO and Write_FIFO with my specific ports, and have modified the ports. When I run the FPGA program, it initializes to step 7, and then exits with the following error message: "Too many DMA channels have been requested or some requested are conflicting. The current target has 3 DMA channels." Does anyone have a fix for this? Thanks.
-Daniel Skrabacz
(6,297 Views)
Hi Daniel,
In order to avoid lots of duplicate posts, Paul is answering your question in this thread: http://forums.ni.com/t5/LabVIEW/Module-9870-for-reading-4-serial-devices/m-p/1459422
Morgan S
(6,273 Views)
