How get the precision of MAX6675 (arduino) to labview (VISA)
Hi, i use visa for comunication between arudino to labview, for measurement of temperatures, with the MAX6675 and his thermocuple K type, well, the problerm is when i see the monitor serie in arudino's interface i can see 2 decimal of precision but in labview, only gets integers, i changed the propierties of numeric indicator: data type (double) and display format to 4 digits (floating point), but nothing changed. So the question is how can gets the precision that can see in monitor serial of arduino. I think that the problen isn't in the indicators, maybe in VISA.
(3,331 Views)
Accepted by topic author LPuma
The problem is you are using Decimal String to Number which provides integers.  (read the context help).
You want to use Fractional String to Number.
(3,321 Views)
I don't know what happen to don't see that, well, thanks.
(3,312 Views)
Hello friend, I am very interested in your work, I download the vi you shared but there are several blocks that do not load, can you help me about it?
(2,961 Views)
