How high can TickCount count?
Hello everyone
Does anyone know how high the TickCount in LabView 5.1 can count until
it wraps to 0? The Help says 232-1 but that can't be.
Thanks for your help.
Paul
(3,810 Views)
They should've said "(2^32)-1"
Of course 2^32 ms is about 50 days so I wouldn't worry about it.
Rick
(3,810 Views)
Are there any questions remaining?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,293 Views)
Hi Paul Steiner,
          Its not 232-1 instead it is 2^32 - 1. then again 0
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,289 Views)
Accidentally I ended up on this 14 years old post.
My apologies for making it again "trending".. 🙂
Kind Regards,
(3,287 Views)
