How identify type of control in LabVIEW 2013?
I wanna identify type of each control from front panel of a main VI. When a control is type "tabcontrol" I will determine all contained controls of each tab.
I changed to LabVIEW 2013 for a short time. Unfortunately in LabVIEW 2013 I didn't find a property to identify the type of a control. A condensed code with my problem you can find in attachment.
Can anybody tells me, how I can solve this in LabVIEW 2013? Thank you in advance.
Christian
Christian
Test Engineering
digades GmbH
www.digades.com
(4,046 Views)
Hi CD,
you can check the type (aka class) of a FP element since several LabVIEW versions:
(4,020 Views)
Here's a VI I write a while ago that gets a reference to all controls and indicators.  What I did for detecting the tab control is to cast the reference to the PageSelector class.  If there was an error, you have a normal control.  Otherwise you can perform your recursive operation.
GCentral
(3,992 Views)
Hi crossrulz,
thank you for your help. Have you got this VI also in version 2013?
Christian
Christian
Test Engineering
digades GmbH
www.digades.com
(3,985 Views)
C.D. wrote: Have you got this VI also in version 2013?
Here you go.
GCentral
(3,963 Views)
There's also a VI that ships with LabVIEW that does this:
LabVIEW [20xx]\vi.lib\Utility\traverseref.llb\TRef Get All FP References.vi
It has various inputs that let you decide what kinds of objects you want to dig into, whether you want to include decorations, etc.
P.S. - I discuss this VI (and many, many others) in my Hidden Gems in vi.lib presentation.
(3,947 Views)
