How keyboard control Button in Event structure
Hello
First I am Just a beginner in Labview
I just make a program that Consist of 4 button controling 4 LEDs Using Event Structure
The Problem is I did not want to operate the button by the mouse click but
i want to operate the button using the arrow keys in keyboard
T
Message 1 of 11
(16,894 Views)
Please refer to this VI. Hope this helps.
Message 2 of 11
(16,885 Views)
Thank you
But Can I ask waht is this in the image
Sorry I am just begginer
Thank you again
Abdo
Message 3 of 11
(16,869 Views)
that is an enumerated constant it is found on the numerics palette
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 4 of 11
(16,866 Views)
Message 5 of 11
(16,865 Views)
VKEY is the key you are comparing to or what have you...
you can get to it by left clicking on the rectangle.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 6 of 11
(16,857 Views)
What is its importance
Message 7 of 11
(16,856 Views)
well in you example it is used to compare what key was pressed so that you get a read out of true or false so if I hit the up key the up led is set to true due to the VKEY being = to up
so it is important
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 8 of 11
(16,850 Views)
Hi, I tried implementing your example. I'm trying to use the keyboard to control boolean buttons to make my "throttle bar" move up and down. It works, but I can't get it to switch until release when I hold down on my keyboard. My stop and clear buttons also doesn't seem to work when I put in the event structure.
I'm a total newbie. Help! Smiley Sad
Message 9 of 11
(14,882 Views)
Hi saiko,
when you're a "total newbie" you should at first go through all those free online LabVIEW courses offered by www.NI.com!
Try this:
How did you configure the event case? When putting those buttons inside the event structure you have the tell that structure how/when to handle them. Did I mention the free online courses?
Do you want to use the automatic key press repeat feature? Well, you have to configure the event: right now it's "key press", but you probably want an event like "key repeat"? You may read the LabVIEW help on available events...
Message 10 of 11
(14,854 Views)
