How long does the LV2009 full development suite usually take to install?
I have a Lenovo laptop with a Intel Centrino Duo T2400 1.83GHz CPU w/ 1GB of RAM and 15GB of free hard drive space available and it took about 5 hours to only get to part 15 of 44. Needless to say I aborted the install. When I checked my Hard Drive free space after the aborted install part 15 of 44 took up 13GB of my freee space. Now I am left with only a partial install and only 2GB of free space left on my hard drive. Based on past experience I know that Labview is not easy to remove from a system once installed.
Anyone have any idea why the install is taking so long for me or what I can do to fix my only partial install??
(2,692 Views)
I clicked every option on my sorta new dual core machine and it took about 5 hours.
I have had LV installs interupted many times and I just start them again and it appears to pick-up where it left off (no it does not start at part 43 but the "of X" is smaller after each re-start of the installer).
Ben
(2,689 Views)
Do you know roughly how big the full install is on disk if you install all of the options?
(2,668 Views)
I installed LabVIEW 2009 on two computer's (I did skip several toolkits though) and I believe it took about an hour, two at the most. This was even doing it via a network install using distributions built by the NI License Manager.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,659 Views)
