How manipulate cluster value in array of cluster
I have an array of cluster, connectet to a while loop over shift register.
In the while loop I have to look for a specific cluster (I know the index of the cluster in the array), then compare an I32 value from the cluster to a value from another source. If these values are different then store the new value in the cluster. Else do nothing (next loop).
How can I do that?
I only need to manipulate one value from the cluster.
Thomas
(2,815 Views)
First you need to index out the cluster you are looking for, then use an unbundle or unbundle by name node to extract the info from the cluster, and write back the cluster element using a bundle and replace array element nodes. WSee the attached example.
Chilly Charly    (aka CC)
(2,811 Views)
That's exactly what I was looking for!
Thanks!
(2,807 Views)
