How many TCP IP connection can be open at the same time using LabView 8.5 in a PC using Windows XP operating system?
Do we have a limitation of the amount of TCP IP connection that can be open at one time using LabView 8.5 in a PC running Windows XP operating system?
(2,530 Views)
Each connection has a connection reference, which is just an integer. So, technically, you're limited to whatever the range is for that integer, and I think the connection reference uses an I32. However, while you can have (and already do with a computer connected to a network) multiple connecitons, the more likely limitation is simple system resources as each connection requires memory. What is it that you're doing that you need to ask this question?
(2,518 Views)
