How may I save the chart history buffer in a file (rather than save each data in a loop)?
I'm using LabView 6.0
(2,608 Views)
No problem. Right click on your chart, and select create property node. In your diagram, right click on the property node and select properties, and then history data (should be last in the list). As an output, this should be the history data. Save this to a file using Save to spreadsheet file.vi or similar.
Mark
(2,608 Views)
