How much VISA resources can be opened simultaneously?
www.xinstruments.com - Custom Software for Industrial Automation
www.hdrconverter.com - Picture processing made easy
Message 1 of 10
(5,627 Views)
Hi Alexander,
I've never had any problem when opening VISA resources.
I'm developping a software that involves GPIB instruments and I've tested it with up to 15 different instruments connected on two different buses and I didn't have any problem so far. (Each GPIB address needs its proper VISA resource).
Hope this helps !
Julien
Message 2 of 10
(5,626 Views)
Are you having a problem, or is this a theoretical question?
There is a limit but it is adjustable. By default you should be able to open up to about 250 sessions, but your mileage may vary greatly depending on the type of resources you are opening. If you are having problems well below this limit, then there may be some other type of problem than the one I am thinking of.
But if you are getting around 250 sessions and need more, there are some INI tokens that you can change. While we don't typically document them, I can make an exception. Just let me know if that's the case.
Dan Mondrik
Message 3 of 10
(5,626 Views)
I have a problem in following: when i'm using VISA usb devices i cannot open more then 32 sessions. After they are opened no new VISA can be created. And after i quit Labview (to close all sessions automatically) there is a chance of computer reboot. Is 32 a strict limit, or i can change something somewhere to increase it?
Message 4 of 10
(5,626 Views)
Hello!
I have similar problem, I can open and communicate over 8 serial VISA sessions, but if I open and use one more, then my programm is running more slowly. It seems to block other sessions in reading state.
Message 5 of 10
(5,198 Views)
Although you can have many sesison open only one can be active on the GPIB bus at a time.
If you are using serial, then a shared VI between your threads may introduce delays. Check for re-entrancy on common sub-VIs.
Of course repeatedly opneing and closing ports will get in the way of each other.
Ben
Message 6 of 10
(5,189 Views)
Thank you, Ben!
I use RS232, no GPIB
I don't use any VI, which reads the interface and is not reentrant
I open and close interfaces once, not before each reading
Do you have more ideas, what I can check to solve the problem?
Regards, Eugen
Message 7 of 10
(5,186 Views)
POst a set of images showing the code that seems to be interfearing with each other.
Ben
Message 8 of 10
(5,181 Views)
It's not possible, the project is too big (about 6000 VIs), and all the VISA functions are in many SubVIs.
But, one more information.
I use 3 interfaces with 6 sessions (for each read and write session simultaneously) and 2 interfaces only for write, and 1 interface with one session for reading and writing none simultaneously.
Message 9 of 10
(5,177 Views)
The problem disappers if I close one of read sessions, independantly of the number or function.
Message 10 of 10
(5,174 Views)
