How much memory is used by filters?
The vi I am working with takes 17,500,000 samples per channel over three channels. It will capture it all fine, but when I went to add a filter I was getting a not enough memory error. The target computer is 64bit, so it should have 4gb of memory to use. The samples are stored as doubles in an array, which gives a total of a little under half a gb used for the three arrays. Are the filters that memory intensive, or is there something else going on?
(2,383 Views)
Can you show us some code? Which particular "filter" are you using (filter type, express palette, signal processing palette, etc.). What is the max size of data that does not give you a memory error?
I assume your LabVIEW is 32bit, right? Arrays are contiguous in memory, so you'll run out of contiguous memory space much earlier than you run out of memory in general.
(2,373 Views)
