Wang Shen wrote:
> Using the property node of my knob control I can change the real data
> range programmably.But I want to change the data range shown on the
> front panel ,too. LabVIEW only limit the needle in the range I set
> before, but the range shown never change.
> How can I change the range shown on font panel?
> Thanks.
Hm... I've got a german Version of LV 6i here. But I'll try to translate.
I found something under Axis, Range (german: "Achse Bereich"). It's in
the submenu for the axis.
I've made a little example. You can find it on
http://marco.tedaldi.net/labview/vis/
It's named range-knob.vi
hope, i could help you a little bit.
bye
Marco
