My name is yariv. I am nearly using the same property as you described below, but in a much simplier way:
I have an 16-bit boolean array that represents 16 devices I am controling. I'd like to update the digital graph with 16 plots, each representing a device. Once in a second I am reading that 16-bit-boolean array and would like to represent it on the graph.
How do I perform it?
How do I make a sweep on the graph display that I can see even past history seconds?
Yariv3G
