How printing my curves
I have a VI that acquire some signals
I wonder how to print what i can see in my XY graph.
Where i can find some examples?
I 'm new in labview and i have 5.1 version
thanks for any help
pprovot@ulb.ac.be
(3,193 Views)
The simplest way is to use the "print when VI completes execution" option in
the Execuition option of you VI (access via popup on the VI's icon -> Vi
setup)
There is also the print panel VI in the Application Control group in the
function palette. Look at the help.
Hope this helped !
Matthieu
Pascal Provot a écrit dans le message :
8i7e54$ep$1@snic.vub.ac.be...
> thanks for any help
> pprovot@ulb.ac.be
(3,193 Views)
Hi. You must create a new VI with a XY graph on it, and customize the graph
in the vay you want to appear on the paper ( less black color, ...). You
must select "Show Front Panel When Called" and "Close Afterwards When Originaly
Closed" options in VI Setup - pop-up with the mouse on the icon in the upper-right
corner. You must wire the graph to conector pane - same VI Setup - Show connector,
and use this VI in your VI, wirring the original XY graph to the input in
this printing VI. You can customize the printing format in "File->Print Documentation"
Hope it works,
Vlad
(3,193 Views)
I forgot to say that you must select in the printing VI "Operate-> Print at
completion"
Vlad
(3,193 Views)
