How read values from Waveform (DBL) 1d Array and compare it with a double value
I want to stop my measurement (right side od the VI) when the user defined stop voltage has arrived in the measurement. But I do not know how I can read the voltage value from the waveform (DBL) 1d Array and compare it with the user typed stop voltage? Hope someone can help me with that.
Message 1 of 13
(4,960 Views)
Hey,
Can you please save your vi in an older format?
Message 2 of 13
(4,957 Views)
@simply_me wrote:
Hey,
Here is the VI for Version 8
Message 3 of 13
(4,953 Views)
Here is one way, prob not the most efficient one but it does the job I believe.
Message 4 of 13
(4,935 Views)
Don't use an "=" sign with doubles. Often two double values won't actually be equal in memory even though they look equal to you. This will result in you never getting an equal condition. Use ">=" or check if the value is within a certain range using the "in range and coerce function".
Message 5 of 13
(4,918 Views)
Yeah, I wanted to put >=, but I wasn't sure about his criteria....
Message 6 of 13
(4,913 Views)
But how I can convert it from the waveform datatype into a double array?
Message 7 of 13
(4,896 Views)
use "Get Waveform Components". The y array of double values can be gotten from that.
Message 8 of 13
(4,892 Views)
where I can find "Get Waveform Compenents" ?
Message 9 of 13
(4,883 Views)
On the waveform palette. You should also know how to use the search button on the Functions palette.
Message 10 of 13
(4,877 Views)
