How reading Rpm speed from fp quad 510
I have an encoder of 2500 ppm quadrature differential signal, and i link
this with a FP_quad_510
The value reading count/microsec how is possible to transform in RPM?
Why if i use the FP configurator in the edit device/channel if i setting a
range of -1,25_1,25 coerce the value range at the default range setting?
Courtesly i would like information of field point quadrature encoder end
reading position,speed,reset on the revolution exc.
Thank for answer Nicola
(3,441 Views)
Nicola,
As for converting the count/us into a RPM reading,you will have to do it inside your software program. It's gonna depend on the counts/revolution on your quad encoder. You can then mathematically calculate the RPM and display that on your panel.
Ex: 'count/us value' / (1,000,000*60) = counts/min
> 'counts/min' / (counts/rev of your encoder) = RPM
I am unable to follow the second question but if you mean that your count values coerce when set to +_ 1.25 velocity range setting, it could probably be becuase the velocity resolution at that range is 38.15 counts/s and so you may not be able to see smaller counts.
You can find more information about the position counters, velocity measurement(speed), index status etc in the FP QUAD-510 Operating Instructio
ns Manual at : http://www.ni.com/pdf/manuals/322633b.pdf
To program the QUAD-510 'Reset', right click on the FP-QUAD-510 @x and choose Edit This Device. Then click on Channel Configuration. In the Channel Commands box, press the button that says Create Item. This will create a channel named "Control @Ch0". You can then write to the "Control @Ch0" item as if it was a normal output. Anytime in your code that you write a value of 1 to the "Control @Ch0" item, it will reset Axis 0 (channels 0 and 4). To change which channel you are resetting, simply change the checkboxes before pressing the Create Item button.
Hope this helps,
Pravin
(3,441 Views)
Thank's for answer,
Now i have try to coerce the 1,25 range and i select customer value.This
mode bring the 1,25 range.
Nic
"Pravin B" ha scritto nel messaggio
news:5065000000050000005EB70000-1031838699000@exchange.ni.com...
> Nicola,
> could probably be
> Instructions Manual at : http://www.ni.com/pdf/manuals/322633b.pdf
> Hope this helps,
> Pravin
(3,441 Views)
