05-19-2013 08:12 AM
Hi everybody,
I have some problem with applying a convolution of the image and Smoothing Kernel in LabView. The idea behind this is, that convolution is a point-wise multiplication in the fourier domain. So firstly I want to apply convolution by standart IMAQ Convolute VI and then, to do basically the same, but manually make FFT of image and Kernel and then make their point-wise multiplication then apply inverse fourier transform and observe the result picture. But finally, I get two different results, but they should be the same, I can not get the idea why.
Solved! Go to Solution.
05-19-2013 11:34 AM
05-19-2013 11:52 AM - edited 05-19-2013 11:59 AM
