How run the opc server?
Hi Iskander,
I#4. In LabVIEW 8.6 the NI Variable Manager was renamed to Distributed System Manager. You need to go Tools/Shared VariableVariable Manager.
National Instruments has a utility called Server Explorer, which can be used to verify the function of any OPC-compliant server. If the server works under Server Explorer, then the client program may be the culprit. See the link below to download the Server Explorer.
How Do I Configure my Windows Firewall to Allow OPC Server Communication? I guess you could check this also.
http://digital.ni.com/public.nsf/allkb/8FB44A1162DE1B5F862574440072CF0B?OpenDocument
However, I don't know much more about OPC. I maybe recommend opening a Service Request or posting a new thread with a new question/title..
Hope that we've helped you out some since the start,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
Message 11 of 20
(1,938 Views)
Hi James Hillman
Thanks for the answer
I did all
NAPOPC SERVER don't work
What can I do?
Regards
Iskander
Message 12 of 20
(1,916 Views)
Hi Iskander,
What exactly seems to be happening that is not working?  Can you read from the shared variables, but not write?  Are there any errors?  How have you checked to see if the variable is writing?  Try monitoring your variables with the Shared Variable Manager.  You can find this under Tools>>Shared Variable>>Variable Manager.
Brian A.
Message 13 of 20
(1,895 Views)
Hi Brian A
I started Veriable Engine
But I see nothing on the Shared Variable Manager.
The table of the Shared Variable Manager is empty
Regards
Iskander
Message Edited by Iskander on 12-12-2008 02:13 PM
Message 14 of 20
(1,883 Views)
Hi Brian A
I want to add
I can see monitoring and control  variables on Tools/DSC module/monitor variables
Regards
Iskander
Message 15 of 20
(1,869 Views)
Hi Iskander,
Thanks for the post and I hope your well.
How are you deploying these variables?
In LabVIEW you could test the variable engine by creating a project, and then a library with one variable. The right-click the vi.lib and select to deploy the library.
Or in the dsc module, you can programatically create variables and deploy them.
What steps are you taking to create and deploy?
Hope this helps,
Kind Regards
James Hillman
Message 16 of 20
(1,854 Views)
Hi
Thanks all for the help and attention
My OPC SERVER is working
I have a question.
Where can I find more information about the DSC module ?
Best regards
Iskander
Message Edited by Iskander on 12-18-2008 04:57 AM
Message 17 of 20
(1,823 Views)
Hi Iskander,
Thanks for the reply and I hope your well. (Thanks for appreciating my responses).
What sort of information / aspect of DSC where you interested in?
Some good resources:
Getting Started with the LabVIEW Datalogging and Supervisory Control Module
http://www.ni.com/pdf/manuals/372946b.pdf
Good General Info/Manual
LabVIEW 8.6 DSC Help File
http://digital.ni.com/manuals.nsf/websearch/CAA3FABBF69091798625749800520711
Very detailed!
Latest NI LabVIEW DSC Module Features and Demos
http://www.ni.com/labview/labviewdsc/upgrade.htm
Nice over-view of the product and its updates
Hope this gets you started, let me know 😄
Kind Regards
James Hillman
Message 18 of 20
(1,814 Views)
Hi James Hillman
I have the question
I found in Examples/DSC the project: "SpinnerExamle"
How was created the Control "Spiner"?
Best regards
Iskander
Message Edited by Iskander on 12-23-2008 05:29 AM
Message 19 of 20
(1,758 Views)
Hello Iskander,
The control in the example is an XControl.  You can find a lot of great information on how to create your own XControls here http://zone.ni.com/devzone/cda/tut/p/id/3198.  Hope this helps!
Message 20 of 20
(1,717 Views)
