How send the u array through labview
How to send the unsigned 32 bit  array through UDP.
How to convert the unsigned 32 bit array to byte array.
with regards and warm welcome,
Ramamoorthy S
Message 1 of 13
(5,564 Views)
Try Flatten to String.
Message 2 of 13
(5,559 Views)
You can typecast it to a string and then typecast it back to a U32 array on the other end.
You can also use flatten tro srring/unflatten from string.
Have a look at the example finder for some examples.
Message 3 of 13
(5,557 Views)
one more doubt
how can i copy the unsigned 32 bit data array to unsigned 8 bit data array.
how can i copy the unsigned 8 bit data array to unsigned 32 bit data array.
if above mentioned two are possible means i can convert byte array to string and send the data.
can you please help on this.
Ramamoorthy S
Message 4 of 13
(5,544 Views)
The advice you got above converts directly to/from a string. Have you tried?
(No need for the middleman (byte array to string))
Message 5 of 13
(5,541 Views)
Thanks i got it.
Ramamoorthy S
Message 6 of 13
(5,536 Views)
i am converting and storing 13 byte string to unsigned 32 bit array but it taking space of (13 * 4 bytes)
why?
i should take only max 16 bytes (4*4) size right
Ramamoorthy S
Message 7 of 13
(5,532 Views)
Show us your code. Make sure to include some default data.
Message 8 of 13
(5,527 Views)
this is the code.
Ramamoorthy S
Message 9 of 13
(5,525 Views)
I don't see any typecast function.
Message 10 of 13
(5,522 Views)
