How should I code three booleans....How do I create a case loop or array for using the next available boolean to be used as an alarm for many different sensors?
if a sensor limit is reached, then a boolean indicator acts as an alarm, and if another sensor's limit is reached then the next available boolean's status is true, and so on.
(2,684 Views)
I would recommend using a state machine to accomplish this. The basic state machine structure is a for loop inside a while loop, with a shift register on the while loop.
I created a small VI that demonstrates this behavior. I saved it for LabVIEW 7.0 ("3alarmExample.vi"), LabVIEW 6.1 ("3alarmExample61.vi") and LabVIEW 6.0 ("3alarmExample60.vi").
I hope this helps!
Sincerely,
Liz Fausak
(2,684 Views)
