How should I set up my VI so that I can use the linear fit coefficient data analysis program, when my values are coming from while loops within a sequence structure?
I'm attempting to create a calibration program, using the printer port, and a Vernier Serial Box by modifying a calibration program designed for the serial box.
There are six calibration points, and to collect them, I have it controlled by while loops so that the numbers are taken when a button is pushed, and this is inside a sequence structure so that I can get the six different points. I feed these numbers into two different arrays (for x and y values) and then try to use the linear coefficient analysis on these points, but the values for the slope and intercepts it returns are not correc
t.
If I cut out the array and coefficient analysis, and feed the same numbers in directly without the while loop and sequence structures, it produces the proper values... I don't know why the numbers it is producing are different, and I'd really like to know.
Karinne.
(2,742 Views)
I would use a data manager sub-vi that would be called by each from of the sequence structure that produced a data point. The data manager sub-vi could auto append new items or could place items in a specific entry of an array. Later on when you want to calculate the linear fit, call the sub-vi to return the array of values.
Stu
(2,742 Views)
