How syncronize PCI4472 with cDAQ-9172?
I need syncronize the acquisition of 32 channels from PCI-4472(8 channels) and rack cDAQ-9172(16ch-9233(4modules) + 8ch-9234(2modules)). I tried several arranges but dont get to do work. I have a 9263 auxiliar module if necessary.
Can anyone help me? A second problem when i do the aquisiton without syncronize is get waveforms with differents DTs between devices.
VI in attached. Thx.
Leonardo de S. Cavadas
Maintenance Engineer and Inspection - Bureau Veritas do Brasil
Engineer Metallurgist with emphasis in Advanced Materials
Technologist in Computer Science
(3,096 Views)
Hi Leonardo,
I have a similar problem now. have you managed to do it?
Mariana
(2,885 Views)
Hi Leonardo,
to use trigger from cDAQ-9172, you need an additional hardware-timed digital module to access the PFI lines. The hardware-timed digital module must be installed in slot 5 or 6 to access the PFI lines.
Thus, you can use PFI line from PCI-4472 to synchronize your measurements.
I hope I help you.
Ricardo Ramos
Account Manager
+5511989658513 | ni.com
(2,873 Views)
