How the LabVIEW exposes its controls to the Visual Test/automated test tools?
We are carrying out functionality testing of the applications developed using Labview(G). The regression test suites are develped with Rational Visual Test(automated test tool). Unfortunately any of the LabVIEW controls are accessible to the Visual Test. How does Labview provides access to its Controls (like CheckBox,combo etc.,) to 3rd party Software?
(3,019 Views)
What version of LabVIEW are you using? The LabVIEW 6 (and I believe 5.1) automation server makes a large number of its properties and methods available. One such method is SetControlValue.
(3,019 Views)
Iam working with LabVIEW 5.1, I am trying to access the controls of the LabVIEW panel from Visual Test.
(3,019 Views)
I am curious about this as well. Do the controls in LabVIEW such as sliders, knobs, text boxes, etc. respond to the Rational Visual Test product as "windows" controls? If not, this means we cannot automate testing of our GUI for regression tests of our LabVIEW app. Visual Test does provide for a rough X/Y type of interaction (i.e. click the mouse at point (10,35)) but this is error prone and forces updates to the test script if the interface look and feel is changed for some reason. What is the difference, say, between a native Windows text box and a LabVIEW text box? If the LabVIEW control behaves like an ActiveX control we might be able to get a handle to its properties and methods. If the LabVIEW control is a different animal altogether then we are
stuck. Anybody got an answer to this one?
(3,019 Views)
> we are stuck. Anybody got an answer to this one?
The answer is that LV controls are indeed internal custom controls.
They do not have child windows and they can be automated using the lower
level points and keys, but not via windows windows.
If you want to, you can use ActiveX controls instead of LV controls. In
my opinion, the programming is way more complicated, but it allows you
to make the tradeoff between the editing and the testing.
Greg McKaskle
(3,019 Views)
