01-10-2011 05:25 PM
I would like to 3D plot the data continiousely reading from serial port. As the 3D plot inputs need to be a matrix, how can I cumulate the multiple channel of serial port data into a 2D matix as the input of the 3D plot? I put a FOR loop in a the while loop to make the output a matrix, but the VISA close outside of the loop connection is broken, how to solve this issue? Thanks for your advise.
01-11-2011 06:36 PM
Would you mind posting your code?
01-12-2011 08:21 AM
Yep, some images would help us understand the question. If english is not a good langauge then include the question in your native tongue. So lacking details to help I will settle for decorating this thread with images from an app that "resemble that remark".
The follwing image show the config screen for a 3 axis anemometer and uses a vector to show the air speed.
This is the same application in analysis mode and we can see the concentration of methane in a coal mine (data simulated here) and how methane literaly pours out of the coal as it is being mined.
Take care,
Ben
