How to Avoid Special Characters in string
Hai.
I want only Alphabets & Digits to be entered in to my string.No any other special characters except spaces.How can I do this?
(7,981 Views)
Hi kaustubh,
you can use an event structure to check which key is pressed. If you want to check the full string, then you can use a loop and check every single character if it is in a special range. You can use the corresponding byte value for it.
Hope it helps.
Mike
(7,974 Views)
Hai Mike
Thanks for ur reply.Actually I've used Match Regular With [^0-9][^a-z] as Regular Expression.But the results were not as I expected.I dont want user to enter any Special characters like !@#^>_:">? e.t.c
Hope so I've made it Clear.
(7,972 Views)
Accepted by topic author kaustubh
Hi kaustubh,
see the attached example.
Hope it helps.
Mike
(7,965 Views)
I would allow a few more, e.g. 0 and 8 to allow editing of the entered string (backspace, cursor buttons, delete key, etc.).
Message Edited by altenbach on 11-21-2008 12:49 AM
(7,952 Views)
HAI Mike.
Thanks for your reply
It really worked.Thanks alot.
(7,949 Views)
kaustubh wrote:
Hai.
Sorry, I think you also want to allow the "space" character....
Simply add a 32 to my non-default case to do this. It should now read " 0, 8, 32, 48..122"
(7,914 Views)
