How to Change Indicator to Industrial Display?
I want to customize my Indicator to an Industry based Display like the attached Image. Please do the favor. Thank you. I could customize most of the things but not able make it exactly like 7 segment display look.
(2,545 Views)
Accepted by topic author dhanushmh
Hi dhanushmh,
Several options:
- Use a "7 segment" font for that indicator.
- replace the indicator by an array of clusters containing 7 LED indicators. Use a subVI to convert a numeric digit to the correct LED on/off scheme. (This is a beginner task asked for very often in the forum. Do a search!)
(2,543 Views)
