How to Change Settings so LabVIEW closes
Hello. Basically, after I close a VI, it reopens the main page where it says "Create Project, Open Existing," and then I have to close this after to actual exit the program. I want to know if there's a way I can change the setting so after I close a VI, the program closes and doesn't redirect me to the main page.
(2,141 Views)
Try putting the line "showNoNavDialog=TRUE" into your LabVIEW.ini file.
(2,115 Views)
