How to Convert 1D Array of Digital Waveform to Decimal Numbers in LabVIEW?
Hello NI Community,
I am working on a LabVIEW application where I acquire digital signals using DAQ Assistant. My goal is to convert a 1D array of digital waveforms into two separate decimal (U32) numbers.
Current Approach:
  • I am reading 16 digital lines (0-15) as a 1D array of digital waveforms.
  • I split the array into two parts:
    • First 8 lines (0-7)
    • Second 8 lines (8-15)
  • I need to convert each 1D subarray into a U32 decimal value.
Issue:
  • The "Digital Waveform to Binary U32" function requires a single digital waveform, not an array.
  • I am unable to directly connect the 1D array of waveforms to the function.
Question:
How can I correctly convert each subarray of digital waveforms into a U32 number?
Are there any LabVIEW functions or workarounds I should use?
Any suggestions or example VIs would be greatly appreciated!
Thanks in advance.
(556 Views)
I cannot seem your Vi unless you do a "save for previous" before attaching (LabVIEW 2020 or below)
"decimal" if a formatting convention, not a datatype.
If you have an array and a VI that operates on an element of the array, just wrap a FOR loop around the operation.
(520 Views)
You get a chain of digital signals and want to convert that to an integer?
There's a Digital to Binary array. Combine that with Boolean array to number.
Qestit Systems
Certified-LabVIEW-Developer
(475 Views)
