How to Convert Time Stamp to String for Filename use
Hi ewjammer & Stergios,
strong advice: please use "build path" and "strip path" from the file functions palette when dealing with filenames and path.
Using string functions is not entirely wrong, but will lead to errors the sooner or the later...
Message 11 of 13
(1,811 Views)
To further clarify the "buld path" and "strip path" VIs have support for all the various formats across different platforms. Using them ensures your code is portable. The string functions can be used but as stated above you may run into problems with different file and path name formats. This includes fully qualified paths on a network.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 13
(1,793 Views)
Thank you Gerd and Mark!
Message 13 of 13
(1,784 Views)
