How to Convert sub-vi to dll?
I would to convert all sub-vi in dll to make my program smaller and mybe faster.Someone can help me?
(2,962 Views)
You create a LabVIEW DLL with the application builder. It is an add-on for U$995 or comes as part of the Professional version of LabVIEW. A DLL will be a bit smaller though you can accomplish about the same thing by saving copies of your VIs without diagrams. Make sure you save a COPY because once a VI is saved without a diagram, the daigram is permanently gone and you'll nver be able to edit it again. You might notice a slight difference in speed but all VIs are compiled and not just DLLs and EXEs.
(2,962 Views)
