How to Count Boolean Transitions in large arrays, i.e. waveforms?
How can I quickly count all the boolean transitions in a large array, i.e. something like 2,500 elements.  The array is the result of a boolean "greater than?" comparison, and I am trying to find out how many times the signal exceeded the upper limit.  Thanks!
Message 1 of 11
(5,183 Views)
Hi Jeffrey,
How about something like this?
Kimdino
Message 2 of 11
(5,163 Views)
Is there a way to do this without the for loop?
Message 3 of 11
(5,167 Views)
Hi Jeffrey,
yupp, there's a way 🙂
Message 4 of 11
(5,148 Views)
wire the booelan array to the boolean to 0,1 function and add the array elements
Message 5 of 11
(5,147 Views)
Hi Jeffrey,
I cannot see one.   Why no 'for loop'?
Kimdino
Message 6 of 11
(5,136 Views)
Hi Jeffrey,
Kimdino
Message 7 of 11
(5,136 Views)
Hey unclebump,
Yep, much neater. It shows why you are a PAV and not me. <G>
Kimdino
Message 8 of 11
(5,133 Views)
Hi Kimdino,
thanks anyway 😉
You don't have to be a PAV to use simple boolean math instead of converting every single bit to number...
Message Edited by GerdW on 12-12-2006 05:29 PM
Message 9 of 11
(5,125 Views)
I need to do this on 32 channels, of 2,500 samples, five times per second.  I'm worried about performance issues if I need to explicitly execute a for loop this many times in quick sucession.
Any other ideas?
Message 10 of 11
(5,118 Views)
