How to Create Filter by date Query for access using Data base connectivity tool
I had started my project by reading Access datas, by using an UDL connection,
but now i want to create an access filter using a query that would permit to select two dates, and to obtain all corresponding datas, how to do it using the Parmetrized SQL query?
Remark: i dont know the SQL language
~~~~~~~~~~~~~~~~~~Looking for a LABVIEW JOB (In EUROPE)>~~~~~~~~~~~~~~~~~~
**The Best Way To Predict**The**Future Is To Invent It**
Salimos - View my most interesting photos on Flickriver
(5,742 Views)
Hi salim_mjs,
see the attached picture.
You should also see this or a similar link:
http://www.sqlcommands.net/
Mike
(5,735 Views)
Hi mike,
I want to thank you for your help, i really appreciate it,
i tried to make the code as ur picture, i had no problem to execute it, but i have no data's in the output
i changed the date format, because i suppose that its a short date format in the database.
can you just look at it, and tell me if you can find the problem,
thank you again for your help
(5,724 Views)
Accepted by topic author salimo
Hi salim_mjs,
you have to use the date format i used. It's independent from the format in your database. It has to be "month/day/year".
Mike
(5,721 Views)
Thank you very much MIKE
you are my hero, my problem have been solved
(5,713 Views)
hello again,
i have a little problem,
my program is working perfectly when im running it, but when im creating the EXE, when i try it and saving the file to EXCEL i have this error
Get LV Class
Default value.vi<APPEND>
<b>Chaine d'appel complete: </b>
Get LV Class
Default Value.vi
NI_report.lvclass:New Report.vi
Main.vi
can you help me solving this problem?
thank you in advance
(5,652 Views)
