How to Create HeatMap
Hi Niquist,
I sincerely appreciate your time. Actually I want to create something like the image attached.
I understand my description of the problem is unclear 😊,  the sample image below is what I am trying to get.
Thank you so much
Message 11 of 12
(1,116 Views)
Hi aaliyu,
Use an IntensityGraph to create your heatmap image!
  • Initialize an integer array, with value 0 for each element. Each element will represent one pixel of the heatmap image.
  • Increment the pixel corresponding to the measured location (x-y data).
  • To do the incrementing you need to scale the x-y positions/data to your heatmap image size…
  • define the Z scale (= color ramp) of your intensity graph to suit your heatmap needs…
Message 12 of 12
(1,112 Views)
