How to Create Labview objects in aspx
Hi everyone
I’m trying to access Labview From ASP.net (Using VB). I Have looked at the example code in the link bellow but most of it is out of date and I can't find a way to create the Labview Object to invoke it's Methods (lvApp = CreateObject("LabVIEW.Application")) How do I create the IvApp Object??
Help
(3,393 Views)
Hi
Maneged to Convert the Link above into a ASP.net code which is attached bellwo.
Can anyone tell me the reason it's givin me an error
Compiler Error Message: BC30289: Statement cannot appear within a method body. End of method assumed.
Source Error:
Line 123:        #End ExternalSource
Line 124:
Line 125:        Public Sub New()
Line 126:            MyBase.New
Line 127:            Dim dependencies As System.Collections.ArrayList
Which is generated by one of the asp.net tools.
Please Help
(3,384 Views)
Hi
We do not actually support ASP.NET on these forums. I have found a couple of dedicated Microsoft .NET forums specifically for ASP, take a look at these
http://forums.asp.net/316496/ShowPost.aspx
http://www.dotnet247.com/247reference/msgs/54/274265.aspx
Kindest Regards
YatinM
NIUK & Ireland
(3,359 Views)
