How to Create a GUI and reuse it on a Front Panel
@MoReese wrote:
@Ben wrote:
In control editor;
Set control as Strict
File >>> Apply changes
Set control as normal type def
save and continue as normal.
Ben
Interesting.  I never considering this before.  What limitations of property nodes are you referring to with the use of Strict Type defs?
I don't have them memorized but I believe the background color is one of them.
Ben
Message 11 of 14
(677 Views)
@CarmineS wrote:
The "THIS" is the two prior posts. First using 1D or 2D arrays AND using strict typedef.
Both together solve my question. Since the number of replies was minimal I thought the solution was obvious.
Hope that helps.
There were three suggestions.  So no, the solution is not obvious.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 12 of 14
(676 Views)
Ben
I don't doubt what you say.  I have just never run into this situation yet.  But thanks for the tip.  I'll keep it in mind.
Message 13 of 14
(671 Views)
Another option that not only will allow you to make cosmetic changes and syndicate them to all of your controls but also will let you encapsulate other logic is Xcontrols they are very powerful for this and much much more.
- James
Using LV 2012 on Windows 7 64 bit
Message 14 of 14
(663 Views)
