How to Eliminate specific numbers from a numeric controller based on bollean LEDs?
I have a bollean array of LEDs. When I turn on  specific number of booleans it should effect an ouput numeric controller. For Ex: From the boolean array if I  turn on the 1, 3 and 7 LED, the numeric controller should now only givce ouit  1,3 and 7 numbers instead of all the numbers in sequence. Is there an way to achieve this?
Labview Learner
Message 1 of 13
(4,766 Views)
Sounds like a ring control would work well for your situation.  When you detect an LED change, you add or remove that item from the ring, making it unselectable.
Message 2 of 13
(4,760 Views)
I'm not sure what you are trying to accomplish. What is the controller? Do you really mean an indicator? Is Boolean Array to Number what you are looking for?
Message 3 of 13
(4,758 Views)
How  am I supposed to achieve that. I made a ring controller and created a property node with disableditems[]. But how do I link the array of booleans to the disabled items list?
Labview Learner
Message 5 of 13
(4,750 Views)
HEy Dave,
I see that the output numeric is an indicator. It needs to be a controller so that the user can then select numbgers that represent active LEDs
Labview Learner
Message 6 of 13
(4,748 Views)
Here is an example of what to do. You search for false Booleans and pass their index to the property node "disable items" of a ring.
Message 7 of 13
(4,743 Views)
Use a property node to fill a list box or a text ring control. These can be changed at runtime.
Message 8 of 13
(4,739 Views)
I am using Labview 12.0.1. I see that the vi example is in v13. Can you downgrade the .vi and send it to me?
Thank you,
Labview Learner
Message 9 of 13
(4,738 Views)
Accepted by topic author Ashaironix
Here's a much simpler version of the example given above.
Message 10 of 13
(4,732 Views)
