How to Extract Array from DAQmx Read
I have downloaded a DAQmx VI to measure a voltage. The taskout of the DAQmx Read goes to a waveform graph. How do I convert this into an array so I can manipulate columns (eg: column 3 = function(column 2)) and save the resulting csv file
Many thanks
(1,778 Views)
Hi Geoffrey,
@GeoffreyGodzilla2 wrote:
The taskout of the DAQmx Read goes to a waveform graph. How do I convert this into an array so I can …
Wrong, it's the data output of the DAQmxRead function! Use AutoCleanup on your VI!
It's an array of waveforms: when you need just the sample arrays then use GetWaveformComponent in a loop…
Your question is very basic LabVIEW stuff, so you better re(read) the LabVIEW help!
(1,758 Views)
I am sorry sir. Please direct me to any help you suggest. I do not know what an array of waveforms is. I use python but not LabVIEW but I will learn.
I expected an array of length number of samples and two columns of time and Y.
Many thanks.
(1,732 Views)
