How to Graph
I'm trying to plot the reading of two input modules against each other and I'm having some difficulty and getting very weird results, I've tried the waveform, chart and xy graph and I can't get any to work any guideance would be appreciated thanks
attached is picture and code
Message 1 of 8
(5,102 Views)
try bundling both arrays to a cluster and wire the numeric cluster (brown wire) to the graph.
Message 2 of 8
(5,092 Views)
ok I tried what you said and it graphed something but, it wasn't right, the y axis was right, but the x axis was wrong, cause I know that I had at least a value of 10 and as you can see the x axis didn't go over that far
here are the pics and code
Message 3 of 8
(5,086 Views)
The Current Linear Measurement & Current Load Cell Reading are single values.  They are not arrays. The graph plotted those two points; thus a line.
Message 4 of 8
(5,079 Views)
they are single values, but they are being read a bunch of times and I want to collect each time their being read and plot Current Load Cell Reading vs Current Linear Measurement, I guess I need to save the values being read but I'm not sure how to do that
Thanks for your help
Message 5 of 8
(5,074 Views)
Hi rock,
you need to build arrays from your data to plot them as xy-graph... See attachment!
Message 6 of 8
(5,069 Views)
Thank you very much for the help, one last question is there any way to reset the graph when the program is rerun (ie. so there is no line on the graph when you start the program)
thanks
Message 7 of 8
(5,040 Views)
Hi rock,
I don't have LV at hand, so just this:
Usually a graph only shows what you wire to it. So either you have to "empty" the values (arrays from shift registers?) wired to the graph or right-click the graph, delete any content (data operations) and set to default (also by right-click).
Message 8 of 8
(5,035 Views)
