How to Hide Cluster and Array Imbricated Layers
How can we hide "layers" from clusters and arrays. I've been trying with the Tool Palet with Transparent but it doesn't hide the imbrecated layering. How can I make everything look flat?
Message 1 of 10
(4,803 Views)
Accepted by topic author Foreshadow20
What does "imbrecated" mean?
Try using the classic style for the array container and numeric controls.  When you use the transparent coloring on them, they will disappear.
Message 2 of 10
(4,801 Views)
I'm not shure it will work well because if you put trasparent an element of array, all cells will become transparent...
Message 3 of 10
(4,795 Views)
You don't make the text transparent.  Just the background and frame.
Message 4 of 10
(4,785 Views)
I'm sorry, i was replaying to another similar post
Message 5 of 10
(4,783 Views)
"Imbricated" - I looked it up.  It's a very cool word that I will add to my vocabulary, but I don't see any overlap here.  What are you trying to achieve?  If it's the "recessed" look you are trying to avoid, you could use the system controls as someone suggested.  You could also customize a control and use that instead.
Bill
CLD
(Mid-Level minion.)
Message 6 of 10
(4,740 Views)
I would use the simple controls from the classic palette.
(To make the shading of your current modern controls transparent, you need to make sure that both colors are transparent, so hit the space bar in the color picker and make also the second color transparent)
Message 7 of 10
(4,736 Views)
I replaced the controls for classic and it worked.
For those trying this: You cannot replace directly, you will need to create a new array/cluster with the classic controls. Drag and drop the contents of your previous array/cluster. The order of elements remain the same when moving to another cluster. This was quick and easy as my controls were already a Type def, only had to switch to Strict Type def and everything got updated in 1 click.
Message 8 of 10
(4,682 Views)
Also don't forget to vote for this idea. It will make issues like that easier to handle in the future. Thanks! 😄
Message 9 of 10
(4,678 Views)
I have recently created a set of flat controls, Flatline Controls., which includes 1-pixel-boarder clusters and arrays.
Message 10 of 10
(4,662 Views)
