How to Implement Conductivity and Thickness Calculation in LabVIEW Using Keithley 2400?
I am a Ph.D. student and am new to LabVIEW. I am working on electrochemical measurements and need help implementing a program calculating conductivity and thickness like potentiostat (Cyclic Voltammetry (CV)).
I use a Keithley 2400 Source Meter with a two-electrode setup, but the example I previously downloaded does not include the required functionality.
  • How can I modify or create a LabVIEW VI to calculate conductivity?
  • What is the best way to estimate thickness from the obtained data?
  • Are there any existing LabVIEW examples or libraries that can help with this?
I also have images and experimental data that might clarify my requirements. Any guidance or recommendations would be greatly appreciated!
Thank you in advance for your help.
(426 Views)
Hi sirino,
  • You apply the needed formulas to your measurement data to calculate conductivity.
  • You apply typical formulas to your measurement data to estimate thickness.
  • There is an example driver for your device in the IDNet
What have you tried and where are you stuck?
(424 Views)
